My take on this is you're better off dropping the pan and changing the filter at 30,000 mile intervals. ATF (and engine oil) go bad because of additive degradation AND particle contamination. Granted, the filter will remove major particulates, BUT NOT all of it. You will be removing some of these smaller particulates and replenish the additive package earlier if your service interval is 30,000. If you wait till 60,000 miles, the additives are nearer the stage where they're spent AND particle volume will be much more. Wear is therefore expected to have occurred more in this situation.
