Originally Posted By: TurboJim
Why do people insist that ATF has good cleaning properties?
Will something other than ARX do? [Re: rsylvstr]
beanoil
Loc: Midwest, Illinois Well, what the heck... I'm giving it a try. I found some deposits yesterday when replacing leaky VC gaskets. The patient is a 95 Chevy K1500, 350 V-8. 151500 miles, all on whatever cheap conventional my Sis could afford, when she could afford it. I bought the truck from her with 150k on it, and have been running Maxlife. You would never know this truck was sludged up... runs smooth, no smoke, minor oil usage (assumed leaking out of VC area), and 17mpg while towing. So, today, I did it's spring oil change, 4 quarts of Delvac, 12 ounces of Neutra, and 20 ounces of Dexron II. Used a Maxlife filter for the inevitable sludge catching that will go on. I had all this on hand, thus the motivation to try it and see. It will take a several months to rack up 800 miles, so we'll see what happens. If the Neutra works, Schaeffers is local in downtown Saint Louis, and I'll begin to use the recommended 1 ounce per quart when I change oil. If not.. I'll give ARX a try. BUT... the burning question in my mind is.. How do you stop the formation of sludge in the first place? We have UOA's to show performance and wear trends, but how would you go about analyzing the sludge to determine what it is made of? Is synthetic the answer? HDEO's? Blends, Brews? Pictures of regular M1 users engines certainly do not look like what I saw under the valve covers, but do they tow trailers, and have a constant temp reading of 210? Or is it a function of miles, regardless of oil type? The truck specs SG oil... I'm sure it had gallons of it in it's early life. Maybe the sludge is from that oil... The world may never know.
_________________________
Will something other than ARX do? [Re: BrianWC]
beanoil
Loc: Midwest, Illinois Update..
700 miles including towing the trailer (5000 pounds loaded, plus firewood and moped in the bed of the truck) have passed. I dropped the oil today. Filthy pretty much describes what I saw. Black. Black cat in a barrel at midnight black. No deposits left on the side of a beaker when swirled like a wine taster, but black like 5000 mile oil. No grit when rubbed between the fingers either. Replaced it with 4 quarts of Superflo, and one M1 for a 20% blend and a P1 filter. If the color is any indication of cleaning, (I know it isn't. That's a very subjective observation at best.) the Neutra certainly appears to work. I'm impressed with Delvac also. Oil pressure was consistant, and it looks like it holds dirt well. If nothing else, an interesting experiment.
beanoil: Tough under heat, real dirty afterwards.
It seems this gentleman followed Bob's suggestion of using 12 ounces of Neutra and 20 ounces of ATF and he believes that Neutra seems to work.
