I just bought a 1/4" drive stubby ratchet at Lowes...musta been Kobalt. It works well.
It worked beautifully doing the first oil change on my new Corolla Cross. There's a small covering plate underneath to remove with 10mm nuts. 14mm drain plug. 3/8 drive adapter for the oil filter wrench.
It's all I need, with a drain pan-container. The DIY mechanic can just climb under from the front on this vehicle--no need to lift; no ramps; no jack stands.
