Hi guys I drive 300 or so miles a day for work. All freeway. Using Amsoil xl 5w30. What interval would you change out at considering my driving type? Appreciate your input.
Does your Escape have the IOLM? If so, what OCI does it suggest?
Seems to always go 10,000 miles no matter what oil or what season
Been doing around 7 or 8,000 milesWhat's your current OCI? 10K miles?
Get a used oil analysis done to understand fuel dilution (if any) and TBN at your current interval then keep adding mileage with each used oil analysis. Remain consistent with oil brand/weight.Been doing around 7 or 8,000 miles
It's their "mid grade" on par with most off the shelf extended drains. Their OE is the next lowest tier and recommends following OLM from manufacturers.I agree with 15K after a used oil analysis. Also, isn't Amsoil XL their lowest tier oil? I'd probably use Mobil 1 Extended Performance or Castrol EDGE gold for probably the same cost as that Amsoil.
(Same 7-8k) .... Mobil 1 Extended Performance Triple Action 5w30 or Mobil 1 ESP 5w30.Been doing around 7 or 8,000 miles
XL = Mid level, very good oil. Not sure why the recommendation to change oils.I agree with 15K after a used oil analysis. Also, isn't Amsoil XL their lowest tier oil? I'd probably use Mobil 1 Extended Performance or Castrol EDGE gold for probably the same cost as that Amsoil.
Yeah that would be a big factor in determine just how far and frequently I’d want to run an oil.Somebody already asked but didn't get a response. Is it an Ecoboost?
