Originally Posted By: StevieC
But I do know.
And it must obviously be a concern for Dodge if they have a Hot Oil message appear in the manual and a limp mode instituted at some point.
Chrysler apparently decided to run this engine closer to the edge than is typically the case for low-perf engines.
The limp-home mode should reassure you, since power output is greatly reduced to keep oil temps out of the danger zone, allowing the oil to cool at these reduced outputs.
You're also running an oil that's probably better than something off the shelf.
Installing an oil cooler would defeat the design goals Chrysler apparently had in mind with this engine.
But I do know.
