20k miles on a lemon-sized filter?
Quote:
Quote:
My Acura 2.0 calls for OC at 10k and FC at 20k. I have a clean engine with 20k. I will be doing 3-4 months about 8000 miles and leaving my Mobil 1 filter on through 2 changes. Problem? fwiw, I use Super Tech filters too, having no problems with them. Also I have no filter OCD problems, I re-use filters all the time. So, 15k on Mobil 1 filter or a biggie Wix I have for summer?
Why, filters are cheap. I change my Amsoil EAO filter every six months along with oil. I average between 5000 and 7500 miles.
EaO filter is cheap? $15 compared to a $3 discount filter.
and you use it less than half it's interval?
if you use conventional oil then your fine.
Quote:
Quote:
I've gone 18K miles with a Mobil 1 M1-104, so the K&N should have no problem going 20K miles.
did you cut open the Mobil 1 filter after 18k?
I just cut one open with 20k using Mobil 1 oil and I found
that the filter was in good condition and still filtering, but I was not impressed with the sluge particles I found in the filter.
filter quality is exceptional to most other bargain brands, but oil still creates sludge, not what I expect from full synthetic Mobil 1 oil
Then you need to change the oil more often.
I didn't cut it open , but now that you mention it ....I have another M-104 that I will use and post the pics.
I was just working through some pricier filters, but agree that $2 Super Tech filters should get changed every time.
I just wonder if there is not some way to test your filter without destroying it? What about checking for flow and pressure?
IMO cutting open a filter to look at the inside to see if it is filtering ok is kind of like opening your computer case to see if your computer has a virus.
I open filter's regularly and find engine condition in real time, any engine in new condition wont have any visible metal,sludge at any milage interval using only the best oil and filter's any visible metal and something is making contact inside the engine. lubricant's have to stay a lubricant in severe service, not make sludge or be consumed by the engine or get contaminated in such short order, unless your using certified oil, then it is ok.
if you want to check flow and pressure the gauges on your dash should help you
Quote:
Oil pressure gages can not check flow, only pressure. If the filter is plugged and in "bypass" you will still show pressure, right?
Not sure I understand the "cerified oil" part.
Depends. You can determine flow ..or rather alterations to flow by your pressure readings ..with a little mojo.
