Originally Posted By: boraticus
Any machine that has been brought up to operating temperature and run like that for a while will not have water in the oil when it's shut down. If stored in a shelter where it won't be rained on or have water physically pour into the engine, it will not accumulate any significant amount of moisture from condensation.
Oil condensation issues are generally caused by engines being run in cold temps and not being brought up to operating temperatures.
Run the engine until it's hot, put it away and don't sweat it. It will be fine.
This is 100% the truth. It is one major reason for motorcycle engine failure that I posted above. So many people start their bikes for 10 minutes in the Winter (dealers do it as well when storing bikes) to "keep them oiled up" and don't realize that is by far the worst thing you can do to an engine. Then 3 years later their cam bearings fail causing engine failure because pieces of the failed bearing stick in the gerotor oil pump.
