Measuring engine oil viscosity
The Society of Automotive Engineers developed a scale for both engine (motor oil grades) and transmission oils.
Viscosity is notated using the common classification “XW-XX”. The number preceding the “W” (winter) rates the oil’s flow (viscosity) at zero degrees Fahrenheit (-17.8 degrees Celsius). The lower the number, the less the oil thickens in cold weather.
The numbers after the “XW” indicate viscosity at 100 degrees Celsius and represent the oil’s resistance to thinning at high temperatures.
For instance, oil with a 5w30 grade thickens less than oil with a 10w30 grade in cold weather. Oil with a 5w30 grade thins out more quickly at high temperatures as compared to oils with a 5W-40 grade.
During winter and for cars used in cooler regions, your engine will benefit from using oil with low winter viscosity. During summer and in hotter regions, your engine will benefit more from oil with higher viscosity at 100 degrees Celsius.
When comparing oils, it is important to take into account the location in which the car will be used. Thin oils that are less prone to thickening in low temperatures will help you start your engine more quickly in winter while thick oils that are less prone to thinning in hot temperatures will help your engine perform better in summer. As a result, 0W-20 and 5w30 oils have been developed for colder climates while 15w40 and 20W-50 oils have been developed with hotter climates in mind.
