Posting for @OhioTech.
This is a followup UOA to this one in June.
2022 Mazda CX-9 - High Performance Lubricants PCMO 10W-20 - 4,987 Miles
Here is the VOA for this oil.
High Performance Lubricants PCMO 10W-20 VOA
In previous OCIs, this engine has exhibited a high amount of fuel dilution. A decision was made to switch to HPL PCMO 10W-20 as it is straight base oil with no VII and holds up well to fuel dilution. This OCI was run about 50% longer than the previous OCI. The engine did see a bit of short tripping and idling with some long distance drives mixed in.
Iron (Fe) total content increased slightly from 14 to 15 ppm.
Iron (Fe) accumulation rate per 1,000 miles dropped from 2.81 to 2.08 ppm.
Copper (Cu) total content dropped from 26 to 8 ppm.
Copper (Cu) accumulation rate per 1,000 miles dropped from 5.21 to 1.11 ppm.
Silicon (Si) total content dropped from 28 to 18 ppm.
Silicon (Si) accumulation rate per 1,000 miles dropped from 5.61 to 2.50 ppm.
Fuel dilution increased from 2.9% to 4.3%.
Fuel dilution per 1,000 miles increased from 0.58% to 0.60%.
Code:
Vehicle: 2022 Mazda CX-9
Engine: 2.5L 4-cylinder turbo GDI
Total miles: 12,319
Miles on OCI: 7,211
Wear Metals (ppm)
Fe - 15
Cr - 0
Ni - 0
Al - 6
Cu - 8
Pb - 1
Sn - 0
Cd - 0
Ag - 0
V - 0
Contaminant Metals (ppm)
Si - 18
Na - 4
K - 0
Multi-Source Metals (ppm)
Ti - 1
Mo - 557
Sb - 0
Mn - 0
Li - 0
B - 0
Additive Metals (ppm)
Mg - 1850
Ca - 1117
Ba - 0
P - 683
Zn - 805
Fuel - 4.3%-GC
Soot - Water -
KV100 - 8.1 cSt
TBN - 7.81
Oxidation - 28
Nitration - 15
