First timer here.
API SN-RC and all previous categories
ILSAC GF-5
ACEA A1/B1-10, A5/B5-10, A1/B1-12, A5/B5-12
Oil was in service from May to Oct (six months). Temps ranged from 30c to 10c. New OEM oil filter and AEM dry flow engine air filter were used. I drive it fairly aggressively on a daily basis, but rarely go WOT (maybe once or twice a month, just to stretch its legs). Mileage on the vehicle was 29127 km (18099 mi) at the time the sample was taken. I regularly change the oil every 7000-7500 kms, and I use a new OEM Mazda oil filter (PY8W-14-302) every time. It's fueled with Shell 91 only. During the last fuel fill before the oil change, I added a bottle of STP fuel injector cleaner and ran the tank to almost empty, then changed the oil (and took this sample).
The car has a CorkSport air intake modification and a throttle response controller. Nothing out of the ordinary to report as far as ownership. The CX-9 has over 30000 km right now and appears to be running perfectly fine so far.
Previous oil change (not reported) was Pennzoil Ultra Platinum 5w30 with 6750 km (4194 mi), new OEM Mazda oil filter with AEM dry flow engine air filter in use.
UOA was performed by Bureau Veritas in Edmonton, AB.
Code
OIL PUP 5w30
MILES IN USE 4.6k
MILES 18.1k
SAMPLE TAKEN 10/16/19
ALUMINUM 2
CHROMIUM
IRON 15
COPPER 3
LEAD 1
TIN 1
MOLYBDENUM 51
NICKEL
MANGANESE N/A
SILVER
TITANIUM 2
POTASSIUM 2
BORON 64
SILICON 21
SODIUM 1
CALCIUM 2415
MAGNESIUM 13
PHOSPHORUS 663
ZINC 728
BARIUM
VANADIUM
ANTIMONY 1
INSOLUBLES N/A
WATER
FLASHPOINT �F N/A
SUS VIS 210�F N/A
cSt @ 212�F 8.4
VISCOSITY INDEX 179
PDF copy of report attached.
ILSAC GF-5
Code
OIL PUP 5w30
MILES IN USE 4.6k
MILES 18.1k
ALUMINUM 2
CHROMIUM
IRON 15
COPPER 3
LEAD 1
TIN 1
MOLYBDENUM 51
NICKEL
MANGANESE N/A
SILVER
TITANIUM 2
POTASSIUM 2
BORON 64
SILICON 21
SODIUM 1
CALCIUM 2415
MAGNESIUM 13
PHOSPHORUS 663
ZINC 728
BARIUM
VANADIUM
ANTIMONY 1
INSOLUBLES N/A
WATER
FLASHPOINT �F N/A
SUS VIS 210�F N/A
cSt @ 212�F 8.4
VISCOSITY INDEX 179
