OVERKILL
$100 Site Donor 2021
I wasn't nec
I wasn't necessarily recommending an 0W-20. Just specified the lightest weight oil that met MS-6395. I was more referring to the tendency to want to run a higher HTHS oil like a 40 grade vs a 20 grade. Yes quality control of lifters was (and possibly still is) suspect, yes the cylinder deactivation introduces additional stresses, valve float can play a role but yes a higher viscosity oil can contribute.
Again, I doubt it, or the SRT's, which use the same lifters and same MDS components would have MUCH higher failure rates, but it's quite the opposite. My dealer has never done lifters on an SRT for example.
Valve float can hammer the rollers and was a theory I mentioned in the other thread, but it may just be poor QC by the supplier, as GM experienced the same problem with their AFM engines.
