Originally Posted by dlundblad
Originally Posted by The Critic
Originally Posted by Brian123
Pennzoil Ultra Platinum 5w30
Originally Posted by Triple_Se7en
+1..... if you don't mind buying it online at Walmart.com.
You will need two jugs anyways. So that means free shipping.
Valvoline Advanced, Castrol EDGE Extended Performance and Mobil 1 Extended Performance, three more good choices.
Want to spend more?...
Schaeffers 9000
AMSOIL Signature Series
Red Line
Want to spend less eventually?....
Castrol Magnatec
Quaker State Durability
Rotella T6 Gas & Truck
The truck calls for a MS-6395 compliant 5W-20. If I am to deviate from this spec, there needs to be a compelling reason for it. Schaeffer's/Redline/Amsoil/Mobil 1 are not MS-6395 compliant.
Double check the manual. Is there an area where it says 5w30 can be used? My brothers 2016 Jeep's manual does.
Mine does as well, and at the first OCI [a short FF run and dump] 5W30 went in, and I stuck with it.
Schaeffers 9000
Red Line
Castrol Magnatec
