2019 Subaru CVT fluid change
Where Jackie Jr got whacked
Was not too difficult just minor glitches. Fill plug was in fact torqued in by a gorilla. 1/2” breaker bar to pop it loose. Immediately started pouring out. Then plug in pan next. All into a big pan. Measured what came out at about 4-1/2 quart's, filled fluid pump I bought for trans services with about that much. Pumped it all in, started it up and ran through the gears a couple times. Measured pan temperature at about 100 degrees, unscrewed filler adapter and nothing came out. Put a little more fluid in pump, attached an angled nozzle and pumped some more in until it just started to dribble out. Threaded plug in and done.
Note that the Eyesight system doesn’t like you running the car with the hood up. It set set an ABS code running it on the stands. Cleared and all seems good.
Fluid that came out was very brown, might talk him into another change next oil change.
a 2nd flush would be ideal that's what I had done.
Just over 60k miles, Impreza, Idemitsu CVTF SB2.
