- Joined
- Oct 6, 2020
- Messages
- 2,232
I'm thinking I'm going to change the pan/filter and the fluid on BMW X3 with the ZF 8 speed. But, without jacking the car off the ground. I can fit under the car just fine. I don't use jacks or ramps for the oil change. The fill plug is really easy to get to.
I'm planning on using the genuine pan/filter. https://www.fcpeuro.com/products/bmw-ga8hp45z-ga8hp70z-oil-pan-and-filter-kit-zf-24118612901
And Valvoline Maxlife for the fluid.
I'll measure what comes out as a baseline. I'll use a hand pump to pump a little more than what came out. I'll start the car, shift through the gears, and use an Infrared laser temperature gun for the final fill.
Let me know what you think (good and bad).
