What exactly don’t you believe about the report?
I, along with plenty of others have done back to back analysis of the same oil between two labs or more. Everything is within normal tolerance between equipment.
I dont understand this bashing of blackstone and their unorthodox way of measuring fuel. It’s close enough.
You seriously going to freak out over a percent or two?!
If they were showing 280F flashpoint and posting 2% fuel, I can understand us raising an eyebrow because that’s clearly absurd.
You can clearly tell this oil has SOME fuel in it based on the FP they got and that is GOOD ENOUGH to interpret the OVERALL condition of this oil. Viscosity is fine. Wear is fine. These engines fail outta the blue. Obviously the failure happened 5,000 mile after this UOA and no lab could have predicted that because there’s no indication of any BOOM in this report.
