2016 Mazda 3 - Engine Oil
xsr
Hi everyone,
I own a 2016 Mazda 3 with a 2.0L Skyactive engine. According to my owner's manual, the recommended engine oil for my car meets the ACEA A3/A5 or API SL/SM/SN standards and has a 5w-30 viscosity.
Based on this information, would the following two oils be suitable for my car? And if so, which one would you recommend?
Thanks in advance for your help!
only if you want to spend the money on Luqui-moly,,the moly gen 5w-30 is a excellent oil & will serve you well. for the money go shopping at Walmart, check out Valvoline Ep 5w-30 or whatever name brands brands (SP,GF-6) that you may like will work fine too. Use a good filter and oci around 5 k.
