2016 Mazda 3, Brembo brakes squeaking
xsr
Hello,
Brake pads were replaced about a month ago and they are squeaking pretty bad.
I've been trying to fix this and nothing seems to work.
Things I've tried:
* Using brake cleaner to clean the rotors and the back of the pads.
* Cleaning the pads with a bit of water.
* Greasing the pins, ears and the back of the pads.
Any advise? Should I get TRW/ATE pads?
If they are ceramic pads then they will squeal when cold and possibly chew up rotors.
Try beveling the edges as per image:
