2016 Fusion rear brake job
Staten Island, NY
On the driveway was placed a good friends 2016 Fusion 2.0 EB Titanium AWD, call it 60k on the clock
Guard green over grey leather, 🪒 💯👍 looking car
Got A/C seats, and a sunroof, it's a quick and comfortable cruiser
However, it needed rear brakes, badly, was down to the backing plate
My friend tried, but couldn't get the rotor off the hub, so he deferred to me, I've never done one of these but it didn't seem too difficult
My first time dealing with EPB, and it was a non issue, I much prefer it to brittle rusty and crusty parking brake cables or shoe in hat design
Oh, have the 19.5mm socket, because Ford still can't make a lug nut to save their lives
Lifting this car is tricky, I think I need to order a pinch weld adapter for the jack, because there's really no good place to lift
You'll need a 7mm Allen, a 15mm for the caliper bracket, an M10x1.5 bolt as a forcing screw if rotors are equipped
The lube was silicone paste on the pins, and Silaramic on everything else, because that's all Advance had on a Saturday AM, I don't think it'll be too bad
For reference, this car is a '16 with 60k, and these aren't even the factory rotors and pads, they've been changed at least once before
I guess the AWD and Torque vectoring/Advancetrac really leans on rear brakes to keep this show on the road?
The rotors are the Motorcraft service line coated, the pads are Motorcraft
He didn't like the feel or longevity of the previous aftermarket job, so he spent the money here
It would've been nice to do some bleeding, maybe get the dial gauge out to match mount and check runout, but the time wasn't there, and he's most satisfied with how it all came out
I went heavy with the anti seize on the hub because for some reason, these new rotors didn't have provisions for the forcing screw, hopefully it'll pay off down the road
Now when you do the onboard song and dance to put the EPB into maintenance mode, it works beautifully
Unlike older Ford's, you don't need to turn the piston in, you just compress with the Lisle tool as illustrated
And it's true, they slide right in no problem
Until you go to put it together, and it won't clear the new thicker rotors and pads
Apparently when you let it get this bad, you've gotta wind them back maybe a half turn to gain the clearance you'll need, luckily I've got the tool set for Project Milan's rear brakes, made quick work of it
So yeah, you may still need to wind back the piston just a touch to fit the caliper over
Exercised the EPB a few times, it self adjusts beautifully, picking up the slack
Pedal feel is good, got the ABS kicking in once or twice, checked the fluid level, torqued the lugs, sent it on its way
Arrival to departure was 3 hours, the more attentive and less rusty will probably do better
10/10 would do again
Nice write up and photos and info. IMO, I’m not a fan of electric parking brakes; had troubles at work with them especially when vehicle battery was to die. That’s just me. I have some short and long jumper leads for making the e brake piston push back in.
Thank You sir 🥃🇺🇸
Nice work! Pretty amazing that someone could bang through a set of pads on the Fusion so quickly. I had a 2014, used it as a rep car in Houston Texas so tons and tons of heavy traffic driving. Changed the pads at 95,000 and they were half worn, rotors were true and had plenty of life left in them. Still have that dang lisle tool, 3 years after selling that car.
I had to do the rear pads and rotors on my mom's 2014 Fusion Titanium 2.0EB Titanium last year. It was really easy. The longest part of the job was me finding a caliper piston tool since I am used to needing the turn in style or 4 pot caliper style.
One nice thing on these is the PTU has a drain plug so servicing them is really easy.
  • Like
Reactions: 4WD
I think too much lube on the SS clips. The grease can attract dirt and cause problems. I just put just a little on the pad ears
I have been using spray Muscle Grease on the hubs. I like it better than anti-seize.
Agreed on too much grease. I use a paper thin layer of paste lube to keep rust off rotor hats, hubs, and caliper parts.
That is way too much grease. The pads will likely wear at a taper once dirt builds up. I see this a lot on rear pads when people decide to use an excessive amount of grease on the clips.
The old pads (what was left of them) were bound up by rust, not grease or dirt
And there's no hardware, it's pad to bracket, only lube in between
The one time use bolts are a surprise to me, leave it to Ford :confused:
Excessive lube is duly noted, I'll cut back on it next time around, however I'm not calling it back for a do over
The rotors will be rusted out again before anything else comes of the grease
This is the first car I've seen that's on its second set of pads/rotors in 6y/60k
My experience with brakes and things sticking/binding has always been lack of lubricant, because NYC cars splash through a lot of salty water half the year
I'll cut back on the next one
Did old pads have SS clips in the caliper bracket? The pads should be powder coated meta backing plate if high quality. Maybe some filed the old pad ears for fit?
There is no hardware in this application
The pads were Motorcraft OEM, they had what looked like a good powder coat or very tough paint job on the entire backing plate
Interestingly, it also had peel and stick pads on the back as a shim
Why would they want the pad sticking to the piston and caliper?
No SS clips? I though any modern car would have had SS clips. If you had time I would have painted the area on caliper bracket where the pad ears slide on.
A lot of euro design calipers do not have them.
Painting the caliper brackets adds thickness. Pads may not slide properly.
Nice job. Yes I will agree with others too much grease. However not too much on the hub even here in the south we see stuck rotors and it sucks.
I’m getting ready to replace the original brakes on my moms car 2017 Camry with 27,000 on it. They have 3mm left and 2/32 is the limit in my state for inspection so they have to be replaced and I’m going to do it before they tear up the rotor. Hopefully I won’t have any issues doing that. She does all stop and go to work so that’s probably why they wore out like that because my dad was surprised they didn’t make it to at least 30,000.
