What diagnostic scanner to control 2019 CRV rear e-brake ?
key largo,fl
I know the manual steps to disarm the rear e-brake module for a 2019 Honda CRV but likely there is a diagnostic scanner that can do this for under $100 ?
This is for an elderly neighbor and I promised to replace both front and rear rotors/pads for free if he picks up the parts.
I will pay for the scanner so if there is one to be had, even if more than $100, please recommend as it would make the job need less steps for the rear brakes.
Yes, I have seen all the YT videos on how-to manually disable the e-brake.
I could be wrong here but I think you are going to need a $$$ bidirectional scan tool as opposed to a cheaper code reader.
