Fel-Pro should be good.
Also replace every other gasket you have to remove on your way to the valve cover and anything else that is a common failure item that requires pulling the intake, so that you never have to do it again. For example, you also want a plenum gasket set, which isn't included in the Fel-Pro package.
Also get a set of NGK ruthenium or iridium spark plugs.
