I think your engine is fine. I see only flaking carbon which is pretty normal.. i dont like pinging. Dumb question.. are you sure you got a good thermostat when you swapped ?? A high or low temp can cause pinging. Not saying you have an issue... just asking.
I have looked at a lot of bore scope pics of 3.4 aprox porsche engines as I have been shopping. And your pics would not bother me if I was buying a jeep.
My advice is to run the slightly higher octane gas and maybe change to 5 w 30 high mileage oil. Even if you needed 3 grand of engine repairs at 300 k miles its not a bad cost for the use.
My other advice is not to worry about the engine. But changing trans fluid and both diff fluids and brake fluid and coolant is always smart.
One question I have is this engine difficult to purge the air out of the cooling system completely ?? The pinging can be from air in the cooling system causing high cylinder temps.. again just asking.
I replaced it with a new Mopar thermostat from the dealership which I believe is 203F. I can't be sure it's not defective, but I have monitored coolant temps when driving and find that the new thermostat typically cycles between approximately 203F and 212F. I replaced the old thermostat shortly after the check engine light came on, but I think it had been running cooler ~185F for a month or more before the computer tripped the code.
I am currently running 92 octane because I have been fueling at Costco for about a year and they don't offer 89 octane, otherwise I will run 89 octane top tier from Arco or occasionally Chevron which also eliminates the pinging. I used to run Chevron more often, but can't justify .80 a gallon more for the stuff.
I replace all fluids on a regular schedule. I typically go 5K engine oil, 30K manual trans/transfer case/differentials/power steering/brake fluid, ~75K coolant.
The engine is very difficult to purge air which is why I use an airlift 550000 vacuum coolant filler per the service manual, and follow that up with a spill proof funnel bleed while idling up to 212.
