Just picked up a new to us RAV4.Has 46,xxx miles on it and I was thinking of doing a transmission fluid change as preventative maintenance .Upon doing a little research,it appears as these trans are a sealed unit and "lifetime" fluid.has anyone successfully serviced one of these without going and having them hooked up to the "machine".
I know it takes the Toyota ws fluid but max lifeatf is compatible and have used that in our 12 corolla.
Also plan on changing out the rear diff and transfer to royal purple 75w-90.
Thanks in advance
Thanks in advance
