2014 Ford F550 6.7 Powerstroke type writer tick
Texas
I've had this truck since 2014 and have put 26,xxx miles over those years. Changed my oil and put Mobil Delvac 5w-40 CJ-4 right back in again. Started engine and hear clicky-clack, clicky-clack. Never heard this sound before and remember all the threads on the type writer click. I officially have this infamous type sound.
Question, is this still regarded as normal? Any other Powerstroke 6.7 owners have this sound? Drove 110 miles on a trip and it was still making this sound when I parked to check the level.
Was a little disappointed to hear this sound finally...oh well.
Duramax engines are notorious for the Type Writer Tick, GM even published a TSB stating it was a normal phenomenon & no attempt should be made to repair it.
My Duramax's TW Tick is pretty loud when cold & dissipates with heat.
It's normal, especially after an oil change. There is a TSB explaining that it's normal.
This engine is very unique as far as the valve train design. It's a 32V with 32 pushrods and 32 rocket arms and 32 lifters. Each valve has its own assembly. However there are only 2 mechanical rollers that ride on the camshaft. These rollers house 2 very small hydraulic lifters each. If you saw them with an engine apart you'd know why you have these noises. I have had some of these 6.7 powerstrokes with u godly hours on them and I can tell you there is no mechanical harm to the noise you hear.
Thanks mattd... great info. Never heard it until now. I did notice when resetting oil change reminder engine hours and idle times...which is really cool to know.
I am at 26,660 or so and have like 630 total hours with 70 idle. Good to hear it is normal like I suspected...just caught me off guard. Appreciate all the info.
The noise will only really happen at idle. The highest hour 6.7 I pulled apart had 25,000+ hours on it with about 15,000 idle hours. There was nothing wrong with the lifters.
Incredible. My usage Is a joke compared to those. Thanks for sharing and info on type writer click.
