My 2013 ford edge is showing misfire on cylinder 6. I swapped out coil 5 and 6 to see if it would move to cylinder 5 to eliminate coil issues. Well now the scanner shows misfire on cylinder 3. Now I'm stumped. Keep in mind it only does this if you mash the gas like to pass someone. Only under heavy acceleration. During heavy acceleration it will run rough and jerk a little. The engine light also flashes during this. Everything go back to completely normal in about 20 seconds after the heavy acceleration. I bought 1 new coil and 6 new plugs as the car has 150k miles on it now. I guess I'm just going to change all the plugs for starters and see if it goes away. Any ideas or past experiences with this?
