I'm always short on time, so condensing both units into one thread. I'm not sure, but I believe that the transfer case is probably the factory fill. The rear diff lube report looks too low on iron to be the factory fill, although it came out grey colored, which is what some others have reported when draining the factory fill on F150s. So....
Sorry, but uncertain of what we're looking at here. I bought the truck earlier this year with 81k miles and while it's in great condition, I don't know the service history.
Odometer read 91k miles when these samples were taken. I refilled the rear diff with M1 75W-140 and for the transfer case, I used Valvoline Transfer Case Fluid. The Valvoline TC fluid is said to cover Ford's XL-12, GM Auto Trak II and ATF+4 applications.
Cat SOS reports, tested by Milton Cat in Massachusetts.
Code:
Ford 9.75" rear diff Borg Warner TC
3.55 with electronic locker (electronic shift on the fly)
75W-140 (unknown brand, miles) uncertain, but probably factory fill
Odometer 91k miles 91k miles
Copper 1 40
Iron 333 603
Chromium 2 1
Aluminum 1 39
Lead 0 2
Tin 1 1
Silicon 22 61
Sodium 2 11
Potassium 4 9
Boron 52 25
Moly 1 0
Nickel 25 16
Silver 0 0
Titanium 21 1
Calcium 8 84
Magnesium 1 82
Zinc 14 24
Phosphorus 1134 82
Barium 0 3
Oxidation 61% 11
Nitration 4% 4
Sulfation 64% 19
Visc @ 100C 24.5 5.2
PQI 59 89
ISO 23/23/21 22/20/16
4 micron 50248 38039
6 micron 40489 8495
10 micron 24638 1064
14 micron 12816 438
18 micron 4264 212
21 micron 1444 129
38 micron 382 36
50 micron 287 23
The transfer case wasn't full before I pulled the plug. I stuck my pinky finger in and could barely touch the fluid. After putting in 1.5 quarts (listed capacity), the new fluid was close to running out of the fill hole. This is my first time testing the TC fluid in any of my pickups, so I don't know if my results are as bad as I think, but "yikes!" is what comes to mind.
Guys and gals, check your factory fill fluids. Don't assume that they get it right when assembling a new vehicle.
Code:
Copper 1 40
Iron 333 603
Chromium 2 1
Aluminum 1 39
Lead 0 2
Tin 1 1
Silicon 22 61
Sodium 2 11
Potassium 4 9
Boron 52 25
Moly 1 0
Nickel 25 16
Silver 0 0
Titanium 21 1
Calcium 8 84
Magnesium 1 82
Zinc 14 24
Phosphorus 1134 82
Barium 0 3
Oxidation 61% 11
Nitration 4% 4
Sulfation 64% 19
PQI 59 89
6 micron 40489 8495
14 micron 12816 438
18 micron 4264 212
21 micron 1444 129
38 micron 382 36
50 micron 287 23
