2012 Santa Fe Kirkland 5W30 12K miles
Where Jackie Jr got whacked
Discuss. I think I’ll change the air filter, it looked fine.
You must drive a lot of easy highway miles? All your reports are looking good. What previous oils did you use?
  • Like
Reactions: JC1
How old is the filter? Do you inspect it on a regular basis?
The reason I ask there is some theories that inspecting the filter introduces contaminants when you open the air box.
Wow, nice report.
I wouldn't change anything oil-wise. Keep running the same oil brand and same viscosity. Just drop your next Kirkland OCI to 6k and compare it to this one at 12k.
Reviewing this latest run, lower # of days due to multiple long vacation drives. This is now my daughter’s car, we just used it for these trips. I drove and I run 70+ speeds for 3-4 hours at a time. I will do the next change closer to 10k, but will probably be a longer time interval.
  • Like
Reactions: JC1
Nice report. I'd just keep doing what you are doing. Now you know if something comes up at 12k and you can't get to the change, there's no need to rush or worry about it. (y)
