Mustang_Cougar
Originally Posted By: GMFan
Use 0w20...why would you even want to RISK losing your engine warranty on your car by giving them an excuse to deny you warranty coverage? Isn't part of the benefit of buying a new vehicle to have a warranty?
Mazda recommends Castrol 0w20 in the manual (their official recommendation) but I use Mobil 1 0w20 in my 2.5L because it is easiest to find. I get 31mpg pretty regularly with my 80% highway, 20% rural driving conditions.
Mobil 1 0w20 can be found in 5qt jugs for $25 at my local Walmart...try to find out what days they stock the oil sections because I've noticed if I try to buy a day or two after they've stocked the shelves the 0w20 jugs are snatched up although they seem to be stocking more of it as the demand for it increases. A simple solution is to just stock up on a few jugs when you have the opportunity.
Oil changes on the 2.5L are easy...filter is mounted vertically right in front of the pan.
I drained the FF at 3,200 miles and I now plan to just use the 7,500 mile recommendation as I will get to that mileage before the 6 months.
Enjoy the new car!
I'm actually just doing this run of MC 5W20 to ~3K miles, after which I'll be going to the Mazda recommended 6mth interval w/0W20 (no way I even get close to the 7.5K mileage recommendation). Unless I have a catastrophic engine failure w/in the next two thousand miles, nobody at Mazda will ever be the wiser that I ran 5W20 (and how often do we read of such failures around here?).
Unfortunately, my local Chinamarts don't stock the 5qt jugs of M1; so I'm stuck paying $6+ for individual qts. Luckily, NAPA ran that M1 sale last month and I was able to stock up a bit. As for the Mazda brand recommendation, I didn't see Castrol in my Mazda5 owner's manual...and the weight recommendations are all over the place (0W20, yet 5W20/30 for Mexico). However, I did notice they advise you to have your oil only changed at a Mazda dealership
. That's not going to happen, and once out of warranty, I'll be using the MC 5W20.
BTW: That oil filter observation cut-out in the engine splash guard is a total tease. Have you had any luck removing your filter through the hole? Or do you remove the entire valance (that's what I did). I'm sort of thinking about using my Dremel to enlarge it just enough to allow the filter and oil to drip cleanly into my drain pans...
M_C
Enjoy the new car!
M_C
