2011 Subaru Outback, 2.5L non-turbo engine w/CVT....
Miles on engine, 36,000
Miles on oil, 14,500
Amsoil 10w-30/ATM, Signature Series
OEM paper air filter (changed @30k miles)
Amsoil "EAO-12" oil filter.
4.2 qt sump
0.5 quarts of makeup oil added, 10k into run
Oil in service for eight months - approx 75% highway/25% city
Wear metals:
Fe, 10 ppm
Cr, 0 ppm
Al, 4 ppm
Cu, 6 ppm
Pb, 0 ppm
Sn, 0 ppm
Ni, 0 ppm
Contaminants:
Si, 21 ppm (some is gasket leaching)
Na, 9 ppm
K, 1 ppm
Oil additives:
Moly, 129 ppm
Boron, 37 ppm
Ca, 3190 ppm
Mg, 15 ppm
P, 645 ppm
Zn, 755 ppm
Physical/Chemical Properties:
Fuel < 1.0%
Water < 0.1%
Soot < 0.1%
Viscosity @100C, 12.3 Cst
TBN, 2.62
Oxidation, 61 abs/cm*
Nitration, 18 abs/cm
*Some of this oxidation may be from esters used as the dilutant for the oil additives*
4.2 qt sump
Wear metals:
Fe, 10 ppm
Cr, 0 ppm
Al, 4 ppm
Cu, 6 ppm
Pb, 0 ppm
Sn, 0 ppm
Ni, 0 ppm
Contaminants:
Na, 9 ppm
K, 1 ppm
Oil additives:
Moly, 129 ppm
Boron, 37 ppm
Ca, 3190 ppm
Mg, 15 ppm
P, 645 ppm
Zn, 755 ppm
Fuel < 1.0%
Water < 0.1%
Soot < 0.1%
TBN, 2.62
