2011 Mazda 3 2.0L Oil Opinion
Alabama
Which oil would be best: Castrol Edge 0w20, Eneos 0w20, or Pennzoil Platinum 0w20?
My vehicle is on the factory fill with 720 miles on it.
I drive 5 miles one way to work, in town, so that is considered a short trip, I guess.
I would estimate 50/50 mix city/highway.
I'm easy on the gas pedal.
I've heard good things about all three.
My daughters' 2006 M3 is doing great on Pennzoil Platinum 5w-20 and annual oil OCI's. I don't see the need for 0w-20 in AL. Stick with the 5w-20 IMO. Also leave the FF in until the first OCI at least 5k miles..FWIW--Oldtommy
I agree with 2oldtommy on keeping the first oil change at ~5K-well maybe 4K. Too many dump the first oil too early and with it all the assembly lubs and maybe additives that are needed to protect the engine. You have a good oil filter to remove anything damaging to the engine. All the oils listed are A1 in my opinion. I run PP in my turbo CX7 but, any of the oils you listed would do a great job, if you just follow the factory recomendations on weight & OCI.. Ed
Originally Posted By: Mazda3LA
I keep hearing great things about PP in Mazda 3s. Check out the mazda forums and you will see that most mazda 3 drivers there use PP. Check out the lab reports below. Most of the reports are using PP.
Blackstone lab reports
What I can't believe in those reports are the short OCIs these guys do with synthetic oil.
Well, my MZ3 with 2.0L engine runs the same on whichever oil I put in. I've run synthetics, conventional and synthetic blends in 5w20 and 5w30.
I cannot tell any difference at all, my gas mileage, which I track on a spreadsheet for every tank, doesn't change either as an average.
Probably if I used oil in w40 or w50 range I would see something worth mentioning, but why would I do that?
Makes me wonder about all these claims on Mazda 3 forums raving about PP or other synthetics, as I see no difference
I keep hearing great things about Pennzoil Platinum in Mazda 3s. Check out the mazda forums and you will see that most mazda 3 drivers there use Pennzoil Platinum. Check out the lab reports below. Most of the reports are using Pennzoil Platinum.
Oldtommy/Mazda3LA, Which engines are in your cars?
Char Baby, My daughters '06 MZ3 has the 2.3L engine. Blackstone suggested annual changes after ther UOA came back looking good. Oldtommy
Originally Posted By: OldCowboy
The Motor Oil Evaluator rates those 3 as PP>Eneos>Castrol.
I'd go with the PP.
That site is awesome. I hope they update it soon.
Originally Posted By: 229
I would change to the PP (Group III) and let it break-in some more then to the Eneos.
I think I will do this. PP sounds like a winner to me.
Char Baby, I have the 2.0L. Have always used either Motorcraft or Kendall oil on my car.
The Critic is right, the 2011 Mazda's require 0w20.
I use Mobil 1 0w20 in my 2.5L as it is easiest to find.
I have tried it all in my 07 with the 2.3L engine. Super Tech conventional to Mobil 1 5w20. I've also used 5w30 as well. Engine can't tell any difference, nor any gas mileage difference. I change it 2x a year with whatever is on sale in these tough economic times.
