2010 Mazda 3: One-Year Review
CA
Some of you may remember me posting a thread here and here regarding the Mazda 3 I helped my friend purchase. Well time flies, and it has already been a year since the car was purchased. As promised, I am giving a brief one-year update on the car's performance and reliability. This car was an early build 2010 model (7/2009) on the first year of a model redesign, so I was prepared to experience some first year bugs. But surprisingly, the car has been flawless.
Miles driven: 8,200
Average MPG: Mid 20s (not measured regularly)
Warranty Repairs: NONE
Issues (squeaks, rattles, etc): NONE
Minor or Intermittent Malfunctions: NONE
Required maintenance performed: Oil Change at 3,000 miles ($28); Oil Change and Tire Rotation at 6,000 miles ($49)
Repairs: 1 Flat Tire (Fixed for no charge at America's Tire)
Verdict? So far so good. My friend has no complaints.
My opinion? The car rides too firm for an econobox. The car does not handle well enough to justify the firm ride. Also, the A/C is on the weaker side, but then again, the A/C is the Altima isn't much better so perhaps it is a characteristic that is normal for certain Asian vehicles.
What are your thoughts on the Mazda 3, styling aside? Any questions?
Air conditioning is strong on my Nissan Murano.
My niece has a Mazda 3, and she has had her electric power steering go out momentarily while in traffic on a hot day. I went on a Mazda Forum and found others with this problem. There is even a "power steering problem" warning light. You are to shut off the car, which re-sets the circuit braker for the electric power steering. The Forum says this happens when it is hot and you don't turn the car for a while, apparently the fluid is only pumped through the cooler when you turn the car. Strange problem to have!
I'm curious how you evaluated the handling? I haven't been in a 2010 but the large amounts of rear camber suggest that it must tend to be fairly neutral otherwise they wouldn't bother.
Maybe at stock tire pressures the front tires rolls over abit giving a vague steering feel? I imagine with the fronts at 38 and the backs at 30 it would feel pretty sharp on turn in.
IMO the Mazda 3 is a great small car. Probably the best available for performance and reliability (combination). The 2.3 in my 2005 is smooth, powerful (for what it is) and fairly economical. The handling for a front wheel drive car is fantastic.
I'm pretty sure most electric power steering systems have no hydraulics, therefore no hydraulic fluid. That is the case with my RX-8.
My Mazda 3 (a 2005) does not have electric power steering.
The new design of the Mazda3 is ok, but I like the previous gen one better. I drove an 09' touring, and IMO thought it handled and looked pretty good. If you don't mind a manual trans, the Mazdaspeed3 for both gen is supposed to be a good car.
My thoughts? The fuel economy is just plain sad. It does not even allow the car to be worthy of the "econo" part of econobox.
Dont want to know how much those econobox tires will cost.
I would fully expect there to be absolutely NOTHING wrong with a vehicle with that age and miles. That is to be expected.
I can live with a firm ride, and I assume the car still handles better than its competitors from at least toyota, kia, hyundai, chevy, ford, etc. Weak AC is unfortunate, but common.
I have only 2 complaints, and one of them is subjective.
1. They look terrible.
2. They ROT TO DUST in salt belt areas. Makes them a nightmare to work on even when they are only a few years old.
Other than that, the powertrains are great, and interiors usually feel upscale.
Your sample size of one is not big enough to be sad about. To balance it out I got 34.5 mpg average over 53,000 miles in my '07 hatchback. I could get mid twenties in a corolla or civic if my driving conditions were bad enough. They aren't considered "sad".
Well the Corolla S/XLE trims and Civic LX/EX wear the exact same size rubber. Better not buy one of those either. Or an Elantra LE either. Or a Sentra S/SR/SE-R...I think you get the point.
So initial quality survey's have no valid point then? He should report nothing to us in his review of the car?
Really? one of my friends has a 2010 Accord with like 2000 miles on it, and has been to the dealer 2 times now for CEL on/car bucking/stalling/hesitating problems.
Another one had a VW Beetle that needed an engine replacement at 5k miles.
your comments are exaggerated.
To be honest, the 2010 is really only a refresh, not a re-design like going from Protege to first gen MZ3, so most of the early problems that 2004 MZ3's had are all gone.
Regarding handling, Mazda set a benchmark in the sub 20k category which only Golf can match (not exactly at the same price point though), so really what do you expect, a BMW type handling?
I'm exaggerating? You write it as if after laying out $20k plus for a new car that some failures, dealer visits, etc. SHOULD be expected.
I buy a new car, I expect perfection, NOT having to go back because things are wrong. If I wanted that, Id just buy a used car.
One of the reasons to buy a new car is that it should be absolutely perfect without any need to have anything done but standard PM. Maybe I expect too much from my new vehicles. Ive never had to take my cars back for anything. OK, one time there was a recall to replace the key fob...
Now maybe my new car will come back to bite me, but I fully expect any new car to be flawless, especially in less than a year and less than 10k. How is that too much to ask?
Granted the sample size is small. But the fact that an econobox getting mid twenties is in any way considered acceptable still makes me disgusted. There are LOTS of midsize sedans with far more power and size that get that while sitting in lots of traffic, idling, whatever. So in terms of fuel economy, what is economical about mid 20s?
That does not make it right. $120 (quality) tires on a $15k car still is silly to me. There is nothing economy about bringing my economy car in and having to spend $500 on tires. Where is the economy?
I never said that initial quality surveys have no valid points. But then again, dont people go and buy Toyotas and Hondas and Mazdas and Nissans because of the supposed "super high quality"? Because those surveys supposedly claim that they are flawless and perfect? If I have to take my new car in after less than a year because of things going wrong, can I possibly call it "quality"? Am I not allowed to have an expectation of quality that I don't need to see the delaer for repairs for at least 5 years 60k (besides PM and alignments) because I spent the money for a new car?
We looked at the threes two years ago (same basic design). Other than the fact that it was a little small for our purposes, we also thought the ride was a little stiff, and the AC was widely reported on forums to be not quite cold enough. In South Texas, we saw that as a deal breaker. So yes, I agree with Michael.
Nope - i am just saying YOU wrote as ALL other cars are also 100% trouble free at 8k miles, so the Mazda's reliability reported after 8k was nothing special at all - I pointed out that while that may be something to expect, plenty other (reputed) cars DO and can have plenty trouble at that mileage.
(not SHOULD)
The 4 tires for $99 special no longer exists, especially if you are about tire quality and safety. It's almost impossible to escape for under $500, even on an "economy" car. I wouldn't call those vehicles "economy cars" but rather "compact vehicles."
Cost of ownership has gone up and that applies to all vehicles. Where those vehicles rule are in fuel economy and maintenance intervals.
You're going to be in for a massive shock when that 135i needs it's run-flats changed in 10000 miles, especially since it has 300hp.
oh JHZR2 has a 135i? LOL! I wonder if he has checked Bimmerfest forums - there are several people who have had their fuel pumps (well documented with N54 engines) replaced 3-4 times under 60k miles...
Not bashing that specific model; what I am trying to say with that is: No car is "perfect". They all have something that will mar their reliability at some point.
and I agree with Jeep - a "decent" tire in ANY size is gonna cost around $110-120 these days, if you want safety and reliability and some decent handling from it
A little bird told me he has a 135i on order.
My TL eats batteries. 1.5 years is the most you will get out of one. It will eat tires. Last set of tires would have set me back $700.... if it weren't for the credit for buying an awful set of YK520s prior to the Bridgestone RE760s
We can balance it out even more by checking on what fuelly has to offer for Mazda3s.
My thoughts? The fuel economy is just plain sad. It does not even allow the car to be worthy of the "econo" part of econobox...I would fully expect there to be absolutely NOTHING wrong with a vehicle with that age and miles. That is to be expected.
I would agree with your sentiments. Overall the vehicle doesn't seem like a bad choice but it certainly falls short of being best.
Clark
Clark
I'm sure that most are aware that the "poor economy" applies to the 2.3 liter model, not exactly a direct comparison with 1.8L Civics and Corollas and the 2010 model comes with a 2.5L engine, more in line with the Rabbit but Rabbits fuel mileage is worse.
The 2.0L version on the other hand is a very different story. I consistently get 37-39mpg in road trips going 70-75 mph. My current commute is 100% heavy city traffic, anyone fimiliar with Toronto area and suburbs knows the traffic lights are almost every 100 yards and they are never coordinated, well except for red lights, when you catch one you catch all of them
with short trips and AC useage I manage to average 25-26 mpg and during weeks when my wife doesn't use the car to go to various stores and I don't use AC a can manage 28-29, a mid size sedan will struggle to get 20mpg in those conditions.
Handling is subjective, of course, and you are correct that the 3 does have significant negative rear camber. However, large amounts of negative camber alone will not result in phenomenal handling; a 2G Prius (04-08) typically has -1.6 degrees of negative camber for the rear tires and that vehicle usually exhibits lackluster handling.
The recommended tire pressure for this vehicle is 35psi for front and rear, which is very high for any car. Turn-in is on the sharper side, but the ride is still very firm for an economy car. The 3s actually handles better than the 3i by a long margin; take a look at these tests here:
http://blogs.insideline.com/straightline/2010/01/il-track-tested-2010-mazda-3-i-touring.html
http://www.insideline.com/mazda/mazda3/2...agination_top_1
I think the difference in handling and braking is largely due to the larger and stickier tires on the 3s, and also due to the slightly larger rotors. Once the OE tires are replaced with something stickier, I am certain that handling will improve. When the car was purchased, I tried to convince my friend to go with a "stripped" 3s model without the sunroof, but she preferred the loaded 3i Touring as she did not need the added power of the 3s for her first car.
A mid-20s average is typical for many NA four-cylinder cars. With the growing weight of many subcompacts, you are correct that it calls to question the value of a subcompact or a smaller four-cylinder engine. As an example, my Saturn averaged between 27-29 under my mom's driving. Her new Nissan Altima V6 has been averaging a very consistent 22mpg (+/- 0.5mpg) at every fill-up on 87 over 3,000 miles. That is only about a 20% fuel economy loss for a more comfortable, more powerful and better handling vehicle. With some of the premium subcompacts (e.g. Mazda 3s, VW Golf) averaging in the lower 20s, you are correct that it is difficult to justify an economy class "subcompact" when larger, more powerful cars such as the Altima V6 deliver similar fuel economy.
As for the tires, this car requires a H-rated 205/55-16. This is a very common size and tires are very reasonably price at around $125/tire. Unfortunately, a set of quality tires for most vehicles on the road today will cost at least $450, be it a new Mazda 3 or late-90s Camry.
See the two links I tested which compared the 3i to the 3s. Subjectively, the 3i handles fairly well with little body lean and fairly sharp turn-in. On paper though, it really isn't great. Either way, the handling isn't good enough for a daily driver to justify the sometimes jarring ride. Perhaps a set of more comfort oriented replacement tires will improve the ride quality, but the OE tire pressure requirements are 35 psi Front/Rear.
After some thought, the A/C is weaker on the 2010 Mazda 3 than some other cars, but it is possible that I have been spoiled by my Saturn's A/C. I will have the dealer look at the A/C at the next oil change, which will be soon, as it is nearing 3,000 miles.
I think his is a N55 as he has the 2011.
Clark
I am not sure if there's a clear winner in the economy car segment. The Civic and the 3 are at the top of the class and are fairly competitive with each other in different ways. Both cars also have some notable pros and cons. A Civic coupe was actually another car my friend was considering, but I convinced her to go with the Mazda 3 since it was the one that had stability control in her price range, and I felt that stability control was an important feature for a new driver.
I have actually been quite impressed with the fuel economy in my mom's Altima V6. Her driving is about 70% in-town city driving and 30% short highway trips (- 0.5mpg) on EVERY fill-up in her car. The VQ35DE is definitely not a fuel-efficient engine by design, but the V6/CVT combo has so far, delivered excellent low-end torque with impressive fuel economy. A/C use also seems to have no noticeable effect on acceleration or fuel economy.
