- Joined
- Apr 3, 2026
- Messages
- 17
I have a 2010 Ford Fusion with the 2.5L in it. Recently I replaced the water pump with a new unit. The idler was squeaking awful, so I figured while I was in there, I might as well replace the WP, belt, etc. For context, the WP design has an O-ring seal on the pump body that inserts into a bore in the side of the engine. It isn't like one of the WP's that has a seal on the face of the flange.
Anyway, after I installed the new pump and got everything buttoned back up; I noticed it was weeping and leaking coolant out the bottom. I verified it wasn't leaking from the pump weep hole. The coolant was coming from the flange where it mates to the engine. I torqued the bolts up a little tighter (I had them pretty snug, but I guess not tight enough) and that stopped the seeping for quite a while. Now, it's seeping again and has leaked out all of the coolant that was in the reservoir. Completely bone dry, empty. It's a thousand wonders I didn't overheat the car.
During my inspection, I noticed that the WP bolts were no longer as tight as I initially tightened them, which I found strange. When I reinstalled the bolts, I didn't add any Loctite or sealant to the threads.
Also, when I went to tighten the bolts again, I noticed a little bit of coolant actually squeezed and seeped out from the mating surface confirming my suspicions that my leak is coming from the water pump.
My questions are as follows:
1. Should I just retorque the bolts properly and keep an eye on it?
2. Should I completely remove the bolts, clean them, blow out their holes, and add a little blue Loctite before reinstalling?
3. Should I completely remove the new WP, add a thin layer of RTV around the O-ring sealing area, and then reinstall with some blue Loctite on the bolts?
I don't mind at all doing number 3, but I've always read that these O-ring seals are meant to be assembled "dry" and to not use any kind of RTV on them. Obviously, I don't want to take any half measures either and make sure this thing never leaks again.
