Has anyone else driven a 2009 or newer A4? I test drove one recently and thought the steering feel, or complete lack of, was terrible. It required a lot of effort just to drive straight on the highway because I could never feel what the wheels were doing.
My buddy was thinking of getting one to fulfill his desire to own a reasonably fast AWD sport sedan, and figured he had it narrowed down to either a base A4 Quattro with manual transmission and the sport package (18" wheels and stiffer suspension), or a base S4. He had been to the dealership many times to talk pricing and options, and had taken a couple of short drives in the A4. He had also taken a non-sport-package for a serious test drive but found the suspension to be too soft for his tastes. He complained about the steering, but just thought it was hard to control because of the loose suspension. So, we went to the dealership last Saturday to compare the A4 and S4 back-to-back so he could make a final decision. From the passenger seat, the suspension seemed a little busy but about the right stiffness. He wasn't sure he liked driving it though so we traded seats. In addition to the steering issue, when I attempted to blip the throttle on a downshift the revs didn't even go above 1000 rpm. I had to floor the pedal and delay my shift while waiting for the revs to come up. I also didn't really like the clutch, throttle, and shifter feel, but the steering was what really killed it for me; I didn't enjoy driving that car at all because of that. The one we drove had Audi Drive-Select so we played with that but it didn't improve anything. We returned to the dealership where they had the S4 idling and ready to go, but declined the test drive of the S4 to go check out the 328xi before the afternoon ended. He had wanted to avoid BMW due to the run-flats with no room to carry a spare tire. The 328 was much better to drive - which I expected because we had driven it a few weeks before - though it still had quite a bit of throttle lag and the steering felt heavy and numb at low speeds only. You could also feel the sharper impacts more despite the suspension being otherwise very well composed, but I blame that on the run-flats. A bit of throttle lag is expected on a drive-by-wire throttle, but even the BMW had far more than the DBW system on my Mazda3. It was probably even more obvious to him, as his current car uses a cable throttle.
The other cars we've driven recently in pursuit of an upgrade for his '97 Acura 1.6EL (all used vehicles were certified used vehicles with low mileage, and all cars tested had manual transmissions):
2007 Audi A4 3.2 Quattro with Sport Package: Sport suspension was too harsh. Engine sounded and felt really good though.
2007 Audi A4 2.0T Quattro: Suspension was too loose. Never felt stable.
2010 Infiniti G37 Sport M6 Sedan: I wasn't there for this drive, but he said the clutch was stiff and the shifter seemed too clunky for a daily driver. The suspension was also a little too firm, though the test drive was done with a coupe because they didn't have a manual sedan available. It's only available in RWD with a manual, and he'd prefer AWD if he's spending that kind of money. It also doesn't have fold-down rear seats. Not a deal breaker, but it definitely loses points for that.
2007 Acura TL: Suspension was too soft and loose. Felt a little too big as well. The new ones are available with AWD and a manual, but are far too ugly to even test drive!
2008 Acura TSX: This would be my choice. It's down on power compared to the others we drove, but everything else seems good. If it were available in AWD, he'd have probably already bought one. We prefer the looks of the previous generation, so if he went with a TSX it would be used.
He was initially quite excited about buying a new car, but in the end, it looks like he may keep driving his old oil-burning Acura for a while. He's considering the idea of buying a 2004-2008 TSX, or a 2004-2005 pre-run-flat 3-series, if he can find a nice example of either. The strangest thing about these drives is that only the TSX suspension felt superior for both control and comfort on our typical roads than that of his current car, which has almost 200k miles and is running on the original shocks (yes, they really are original). The BMW would probably have the best suspension if the the initial impacts weren't so harsh. It's tolerable, but I'd definitely like to see what it would be like without run-flats. The concept of not having to change a tire at the side of the road is a good one, but not if it sacrifices ride quality. He's also an even bigger fan of studded tires than I am, so there are no run-flat winter tire options for him (that we know of) and he doesn't want to lose most of his trunk space by using one of the aftermarket spare tire kits that are available. Plus, he wouldn't want to limit his selection and pay the extra cost of replacing the original tires with run-flats when the time comes to replace the tires.
On the drive home, we were also laughing about how much better his old climate control system is. You don't have to push any extra buttons or pull up any menus on the screen to make adjustments; you can just turn a dial or slide a knob and you're done!
That was quite the ramble. Comments?
