The 2002 wrangler I bought brand new hit 200 K today. IMO a wrangler with this milage is kind or unusual here. Most wranglers are weekend toys and not daily drivers like mine is.
It has had its share of problems. Every suspension component has been replaced at least once.
The clutch release bearing ground its self up @175k. and then the Rear D44 axle needed a rebuild shortly after.
Most jeeps have the 3.07 axle gears, mine has the 3.73 and the better axle that still had to be rebuilt when it lost a carrier bearing.
The universal joints in the rear driveshaft are still original. All the ones in the front including the double cardian( sp?) joint in the front drive shaft hace been replaced.
The engine does not burn or leak oil. Transmission and transfercase as well as the front axle gears and wheel bearings are still original.
Oddly enough the original alternator failed today @199995 miles!
I can say that its never been in an accident other than some dingbat bumped me from behind at a red light a couple years ago but didnt cause any damage.
I do feel that it had more pep when it was younger. I figure the timing chain,cam and lifters are likely worn. Typical 4.0 Jeep will still pull from below 1000 rpm in any gear without any pinging or knocking.
It has always made it home under its own power. Never been on a tow truck.
