Originally Posted By: good_jolly
Here is my observation, on cold start it rev freer and higher about 250 rpm than 5w30 and drop slowly and quickly. Today the weather is in the low 50s, on the morning start, it rev higher as usual then the engine was making this weird rpm fluctuation. I shut off the engine and restart, everything back to normal.
What do you think?
I doubt the "weird rpm fluctuation" had anything to do with the oil. RPMs are controlled by the computer and various sensors. One of them for lack of a better term "could have been a little off". JMO
Originally Posted By: bepperb
"I doubt the "weird rpm fluctuation" had anything to do with the oil. RPMs are controlled by the computer and various sensors. One of them for lack of a better term "could have been a little off". JMO"
Agreed. I'm thinking a dirty IACV. I'm not sure if that engine had a MAP or MAF. Could be that the OP is listening a little more closely due to the change, or maybe it is freer to rev. But, that's all computer controlled.
Originally Posted By: Johnny
bepperb, do you think it's cold enough in Texas to justify a 0W oil.
Poor soul does not know what winter is.
Originally Posted By: ARB1977
Originally Posted By: calvinnnnnnnnn
why switch when everything was good?
X2
Originally Posted By: mechtech2
The idle fluctuation is most likely engine management - it could be all sorts of things. Not likely to be the oil, though.
In Texas, I'd probably run 5-30 in that tired engine.
As you noted, feeling a bit more pep in smaller engines is normal and good with thinner oil. It's your call.
Originally Posted By: Winston
Thinner is better.
Problem was not caused by the oil.
Thinner is better.
Originally Posted By: Jason Adcock
I'd probably run a thin 5W-30 in that application. Like Havoline or Chevron Supreme. Those are about the thinnest for their grade (at operating temperature) that come to mind.
+1 on the dirty IACV. My car used to do that when I first got it as well. The RPMs would slightly surge on idle (up and down) when you start it up.
Thank you everyone. I just switched to M1 5w30EP. It doesn't feel as peppy as the 0w20 but better safe than sorry with a high mileage car and follow you wise men advise.
However, I feel like there is a layer of silk cushioning my butt with the EP
Btw, I didn't waste the new 0w20, I drained it in a container for use in another car.
