I am considering a purchase of a low mileage used 2009 Piaggio Fly 50 4T scooter; it currently has @ 540 miles and the dealer is gonna do an engine oil/rear differential service for me (they will be using Mobil 1 0w-40 engine oil...Piaggio specs for 5w-40 engine oil & ??Lucas heavy duty 80w-90 gear oil???...Piaggio specs for 80w-90 gear oil); this engine comes with an oil screen, but I will add a magnetic drain plug to 'enhance' filtration; the clutch is a dry centrifugal type so JASO MA specs don't matter...
I already have plenty of 10w-40 motorcycle oil (both conventional Maxima brand & synthetic-blend Suzuki brand) in stock for my V Star 650 and not sure how stringently I have to adhere to the '5w-' oil spec...
what do you recommend for oil (conventional vs syn-blend vs syn; 5w-40 vs 10w-40 vs 15w40) & oil change interval (considering the engine lacks a 'true filter')? thanks
