Originally Posted By: expat
The muffler on the wifes Toyota Matrix has blown internally, the most reasonable muffer replacments seems to be a Bosal from Rock Auto ($125 ca)
Are Bosal mufflers any good?
Bosal is usually junk. Walker is better but most of the aftermarket exhaust segment is usually aluminized steel junk. If you live in areas with snow and salt, the aluminized steel exhaust parts will be showing surface rust after one winter and will probably spring leaks or fail structurally in two to three winters. I'm not talking about internal failure either between baffles, but holes through to the outside.
I'd look into how much going OEM costs and factor whether the cost difference is worth having to replace aluminized [censored] multiple times in the what, 9 years the last part lasted you?
(that is assuming the one you're replacing is OEM and this is the first replacement)
I have a 2009 car with an original OEM exhaust. I've used both Walker and Bosal exhaust parts (both pipes and a cat) on another car. The 2009 car has a clean exhaust system nine years later in 2018, the other car I used the Walker and Bosal exhaust parts on were showing massive amounts of rust a few months after installation.
