If you're really bored, you can look up the predecessor to this thread, posted by me May 2, 2018. (Where do the years go?)
Before removing the front driver's-side wheel to address a slow leak, I found there was quite a bit of play in the wheel. I confirmed it was not the ball joint or tie-rod end. That left the wheel bearing.
Kia, in its designers' wisdom, makes it such that you have to remove the knuckle/hub assembly to get at one of the three bolts which pass through the knuckle from the back to hold the hub to the knuckle.
I was having a really hard time removing the hub (unlike most of the YouTube mechanics, who typically pop it off with ease).
What worked was an Eric O trick, though beefed up.
I knocked all six studs out of the hub, and inserted three slightly smaller bolts with spacers and a nut on the knuckle side.
Cranked on those with the old impact wrench, flipped the assembly over, supported on wooden blocks, and pounded on the back side of the bearing with a 4# hammer.
Cranked down the three bolts again, and so on, and repeated the process until the bearing and hub popped out. It's basically a low-budget press.
Parts are due in Tuesday.
Question - I was sort of freaked out by the sloppiness of the bearing - if it wears badly enough, can it separate resulting in the wheel coming off?
It definitely needed to be done, but did I avert a disaster rather than some inconvenience?
