2008 Honda CRV door lock actuator
North Texas
Has anyone replaced one? Having issues with the drivers door locking on its own. You can see the lock from the inside of the car slowly want to lock on its own. It unlocks with the key fob no problem.
Sounds more to me like the actual keyless entry module may be bad, it might not be a bad door lock actuator itself. I am no Honda expert but on my wife's 2003 Accord the keyless entry unit is an internal part of the driver's side door lock switch assembly. If yours is the same, maybe you could unplug it temporarily and see if the door lock still has a mind of its own, then go from there with how to fix it.
