Originally Posted By: HTSS_TR
VTEC mechanism will not engage with very thick oil. Some owner of S2000 tried to rev engine pass 60000 RPM right after he left parking lot in evening after work in So Cal summer, what he got was fuel cut off.
I think if engine is operated below 6000 RPM until it is at operating temperature then VTEC will work with xW40. That means owner needs to drive more sedate longer with heavier oil.
This may be misleading. The cause for VTEC not engaging may be the coolant temperature, to prevent engine damage. Most boosted cars will prevent full boost at colder temperatures, so I suppose that a performance variant of VTEC may also prevent engagement due to low coolant temperatures, and has nothing to do with oil viscosity.
Regardless, the R18 VTEC is an economy version, and not even comparable to the SI VTEC, unless you consider that, when the R18 goes into VTEC, it is similar to the cam profile of an SI while NOT in VTEC. It's designed for economy, and will only allow "regular" operation when required for a "regular" performance. There is no sport in the R18, only economy and...regularness.
For the others who say VTEC (variable valve timing) will not engage with thicker oil, why do you say this? Do you have any data to back this up? Do you really think shifting of cam profiles will be inhibited by oil that is a few cSt higher?
Seems absurd to me.
