2007 yukon shudder
louisiana
hey guys, got a 07 yukon with 130k, getting a slight shudder from the while coasting up to stop sign, or when u let off gas at highway speeds, the shudder will last just a second then its gone, and it never shudders while under acceleration. seems to come from driveshaft area or rear end. let me say this, the shudder is something i hear not really something i feel. the car shifts fine and the trans temp is always in normal operating range
Driveshaft U joint seizing. Probably at least THREE on that vehicle. One is part of the so called center bearing so you actually have a two piece drive shaft.
+1. U joint.
