2007 camry 4-cylinder
Houston, TX
I just looked under my new Camry and it has a very small screw-on oil filter. Is there a longer higher capacity filter that will fit this 4 cyl engine? Thanks, Santiago
The small filters work great! Don't worry, Toyota knows what they are doing! I've been running the small filters and the UOAs come back fine with the insol low. Take care and enjoy the new car.. I wish I had one! Bill
If there is room, you can x-reference the PH3614 and PH3600 sized filters. The PH3614 is used on some of the larger Toyota engines. And the PH3600 is the Ford sized filter(FL400s).
