2007 BMW 328i Tires needed
CA
Friend is looking for 4 tires for his 2007 BMW 328i with 235 35 20. Any good rebates or deals out there?
He got offered 4 tires for 150 each mounted and balanced. Two tires are Toyo and the other 2 are Continental.
I told him to hold off on buying and told him I would look into it
[assuming said friend lives in CA -- correct me if I'm wrong]
Options in this size seem limited. As OVERKILL said, the Pilot Sport A/S 3 would be perfect; unfortunately, it's not available in this size.
Luckily, there's this: http://www.tirerack.com/tires/tires.jsp?...num=335YR0PSSXL
Killer tire obviously; well built, grippy, long-lasting for its type, and light. And that particular variant is Ferrari spec, for what that's worth. :]
I don't see anything that comes close, even considering bang-for-the-buck. Do NOT go cheap here -- that's never a good idea with tires, but it's especially bad with a sidewall that small.
20" wheel and cheap? Are you kidding?
Krzys
Agreed.
In this particular size, it's just not going to be cheap, unless it's total khrap.
He should put decent tires on it. Michelin Pilot Sport A/S3's are a good choice.
The 3's are old now, they're A/S 3 Plus now. The size of rims are getting a little ridiculous, whatever happened to 80 series 13 inch rims? You never used to find guys that would fix rims, but they're all over the place now because they crack and bend all the time.
Also, just FYI, but according to TR, the recommended tire size for this car is 245/30/20.
There is a Hankook Ventus V12 available in that size for $175 each, but if it was my car, I'd spend a bit more and get the PSS. Then again, if it was my car, I'd dump the 20" rims and get 17" ones.
Yes, the PSS's are phenomenal and a true bargain for the performance they offer
