2006 Silverado - rear drums or discs
D60
Colo
How to tell from afar? I have the VIN but I'm not sure that will say definitively?
The vehicle in question belongs to my folks and is a couple hundred miles away. Asking them to go look or snap pics will seem overwhelming for them.
I'm guessing from some basic info someone here can say if it most likely got factory rear drums or discs:
-6.0 so the "bigger" rear end (is this still considered a 12b?)
-VIN states 4000# rear axle capacity, 7000# GVWR
-4x4, not badged as Z71 but I believe it has the "4X4" sticker on the bedsides
-crew cab
-LT trim level and pretty much fully loaded except a sunroof
-NOT a 1500HD
Is it possible to have an educated guess?
Probably discs. If someone can kneel down and look underneath, they should be able to see if there are drums or discs. No way to tell from the VIN. If there are aluminum wheels, they may be able to see the shiny disc surface through a "wheel spoke".
-crew cab
-NOT a 1500HD
VIN 2GCEK13N561256595
call/go to a dealer and ask. Not a good idea to publicize your parents vin online.
Just ask them :D
That's simply not an option. You don't know my folks. It will become an all-day stress affair of whirling feces which will end with them giving up and taking it to the local dealer (which is not a good option for reasons too lengthy to explain nor does anyone really care)
Even just trying to snap pics and send to me will be unbearable. In their defense they are BOTH dealing with SERIOUS health issues and CONSIDERABLE chronic pain
I was just kidding about asking them ;)
sorry to hear they're in such pain :(
From a GM truck forum:
The change to rear drums started in the 2005 model year. GM also changed the brake booster, master cylinder and put larger rotors and calipers on the front.
Model year, different combinations of options (stabilitrac, axle ratio, etc.) would determine rear discs or not.
The easiest way is get on the ground behind the rear wheel(s) and look across at the back of the rear wheel/axle on the opposite side. You may or may not see a caliper there.
Or locate the Service Parts Identification (SPID) sticker (typically at the door jamb area). I believe "J" codes are brake related. Once you have the RPO code, you can search for the definition.
Ex: JH1 = Hydraulic Brake Power, Disc/Disc, 6400 lbs
any pics from the side? I would think you could see them.
there are plenty of pretty good free GM VIN decoders...have you tried one?
can you get the RPO codes from the glovebox?
I have never understood this nonsense either.
I usually tell people on this forum to PM or email me the VIN when helping with a Ford or Mazda. What baffles me is people that call into my work for parts and then tell me "a competent parts person wouldn't need a VIN to determine the correct part." They get hung up on.
FWIW we have at least 1, maybe more, GM parts people on this page who should be able to help. But as said elsewhere, the RPO tag on the glovebox should help, even I can maybe figure it out with the lookup I have for GM.
These days VIN's are super important for getting the correct parts. This was drove home recently for me when I was helping diagnose my friend's 2017 Ford Superduty that was setting ABS and traction control codes. One was the RR wheel speed sensor. I finally diagnosed it as bad and I told my friend to have his VIN handy because the Ford Dealer was probably going to need it. I was right because I think he said that there was like 8 possible RR speed sensors listed for that year Superduty truck. The parts guys said he would have never been able to order the correct one without the VIN.
