Originally Posted By: Jax_RX8
Originally Posted By: Johnny
Is the V10 a mod motor?
Yep - same specs as the 5.4 with 2 more pistons added. It is still using the 2v heads though.
Partially true. Some of the newer V-10s also had 3-valve heads. What they do NOT have is the VVT (variable valve timing). The V-10 has been dropped from the SuperDuty line, but it still exists in the Vans, although not in 3-valve form. But for a while, some V-10s did get three valve heads.
Still, they are (and always have been) part of the modular engine family. The blocks are even machined on the same transfer line (or at least they were back when I visited the plant).
