My friend's family has an '05 Grand Caravan. The blower motor had to be replaced a few months ago. Anyway, they say it has been blowing some sort of steam or smoke or something at random, and turning it off and on resumes normal operation. I've never been with them when it happened so I can't describe any more than that. A/C was set to max cold I imagine (Florida summer). Circulation off since it's broken (read on for details). Anybody have any clue what this could be? In case it's something with the heater core, I checked the coolant overflow reservoir and the level seems steady at what appeared to be the MIN line. I didn't check underneath the radiator cap.
The door mixer actuator for circulation is nonfunctional. I traced this to a problem in the wiring harness connector where it clips into the actuator itself. It seems that someone (likely whoever replaced the blower motor) was unable to disconnect this harness properly, and it became damaged. The harness receives proper voltage when measured from the backside of the connector, but when probed from the front there is no voltage. The obvious solution is to obtain another harness and solder it in. My friend and I scoured the local junkyard for the wiring harness, but all the Grand Caravans and equivalents were too old and had different connectors. I'm sure we could temporarily rig some quick disconnects to have working circulation, but is my only option to just keep scouring junkyards, or would the dealer sell such a part?
