Goodbye my love - 2007 Mustang GT.
I had to buy a truck for a new business venture. She is pretty solid and I want to make sure that I take care of the fluids perfectly.
2004 F150 with the 5.4L. 94,000 miles A/T 2WD K&N cold air induction system
What would you change/replace?
I am looking to do
1. oil/filter change with cheap 5/20 and motorcraft filter
2. coolant flush
3. trans pan drop and refill and filter swap
4. good hard look at spark plugs and wires - swap if needed
5. PCV replacement
6. Power steering - turkey baster method
7. Differential fluid swap
my questions are what else would you do and why? And it calls for motorcraft premium gold engine coolant ford part # VC-7-A Ford Specification WSS=M97B51-A1....is this Prestone? And it calls for 75W90 in the rear end (in the owners manual)... has anything else been recommended since? Anyone know if it has grease points for the front end? it is 5:43AM and I don't want to get under her in the dark. Thanks
I am looking to do
2. coolant flush
5. PCV replacement
