My friends younger brother bought a pre-owned 2003 RSX Type-S. Supposedly the car had a new clutch put in 14k miles ago. He decided to do a few donuts with a high rpm clutch drop while his friend was recording. When he dropped the clutch, the wheels started spinning and then all of a sudden-loss of power to the ground and there is now a clunking noise coming from the engine when it's running, more apparent when trying to push the car to roll ( as if the exhaust is dragging against the ground). The car goes into gears when stationary but it wont move at all in first gear or reverse. The rpm's go up but the car does not move.
Needs a new clutch, busted differential, broken axle, transmission shifter cable? What's the best way to diagnose? ABS light also came on after this. Thoughts?
Thanks
Thanks
