Not a good UOA, I didn't think it would be good as the T-stat was reading too cool and the CEL was on. Those have been fixed after the UOA was taken. Also, there's a small leak that needs to be fixed too, probably a valve cover gasket on the back side of the engine. Hard to visibly see it.
I'm looking forward to the next UOA to compare this not-so-good data with data that reflects a fixed t-stat & secondary air injection pump vacuum line that cured the CEL light.
I ran out of Amsoil 0w-30 so I used M1 as a top-off.
Analysis done by Terry at DysonAnalysis.com
Code:
Year: 2001
Make: Saturn
Model: SL2
Engine Size: 1.9L
Total Mileage: 87,200
Fuel Type: 87
Fuel Additives: FP
Oil Use Interval: 5,500
Oil Type & Grade: Amsoil 0w-30
Make-up Oil Added: 1qt M1 0w-20
Make-up Oil Added: & 1/3qt Amsoil 0w-20
Oil Additvies Used: LC
Crankcase Capacity: 4qts
Sample Date 12/28/08
Air Filter: K & N
Oil Filter: M1
Element PPM
ALUMINUM 2
CHROMIUM 2
IRON 13
COPPER 5
LEAD 0
TIN 0
NICKEL 0
SILVER 0
TITANIUM n/a
CALCIUM 2,574
MAGNESIUM 19
PHOSPHORUS 812
ZINC 902
MOLYBDENUM 46
MANGANESE n/a
SILICON 20
SODIUM 46
POTASSIUM 0
BORON 30
BARIUM n/a
cST @40C 46.9
cST @100c 8.7
SUS 210F n/a
Flashpoint F 335
Fuel % 1.16%
AntiFreeze % 0
Water % 0
Insolubles % n/a
Oxidation 47
Nitration 12
TBN 3.7
TAN 2.31
Code:
Year: 2001
Make: Saturn
Model: SL2
Engine Size: 1.9L
Fuel Type: 87
Fuel Additives: FP
Air Filter: K & N
Oil Filter: M1
Element PPM
ALUMINUM 2
CHROMIUM 2
IRON 13
COPPER 5
LEAD 0
TIN 0
NICKEL 0
SILVER 0
TITANIUM n/a
CALCIUM 2,574
MAGNESIUM 19
PHOSPHORUS 812
ZINC 902
MOLYBDENUM 46
MANGANESE n/a
SILICON 20
SODIUM 46
POTASSIUM 0
BORON 30
BARIUM n/a
cST @40C 46.9
cST @100c 8.7
SUS 210F n/a
Flashpoint F 335
Fuel % 1.16%
AntiFreeze % 0
Water % 0
Insolubles % n/a
Oxidation 47
Nitration 12
TBN 3.7
TAN 2.31
