2001 Pontiac Montana
170,000km on engine
10,300km on oil ~6400 miles
no make-up oil added
99% hiway driving.
Esso XD3 0w30
Napa Gold 1036(oversized)
Amsoil TS air filter
Numbers are: left column=UOA, right column=VOA
Tin 0 0
Lead 2 0
Copper 5 0
Aluminum 3 1
Silicon 15 3
Iron 38 5
Chromium 0.7 0.4
Silver 0 0
Zinc 1200 1350
Magnesium 6 10
Nickel 0 0
Barium 0 0
Sodium 9 1
Calcium 2000+ 3800
Vanadium 0 0
Phosphorus 1100 1300
Molybdenum 2 0
Boron 2 3
Manganese 12 1
PHYSICAL PROPERTIES
Viscosity @ 100ºC 11.58 12.07
Water 0 0
insoluables Glycol No No
Fuel Dilution No
I just bought this van a few months back and thought a UOA would be a good idea given the fact that these motors like to leak coolant into the oil.
I looked back through my past UOA's and they all show some sodium, so the 8ppm sodium here could be normal. If there was a coolant leak I would expect there to be more ppm than that.
The lab reports the iron and silicon as "low" which it probably is in the real world, but not here on BITOG, and not according to my previous UOA's on these engines. The van runs fine, nothing unusual, so I'm not too worried at this point. Like I said I just bought it a few months back with 112,000km and I have no idea on it's prior maintenance history. From what I could see through the oil fill hole it wasn't exactly spotless so I could have some cleanup action going on here. This is only the second fill of synthetic XD3, the first few changes I did were done free at the dealer with dino.
Here's my plan: I'm going to change the oil tonight and do a short OCI, probably 5000km, drain again and resample 10,000km after that. I'll also check for an intake leak, there's a breather hose at the back of the intake that likes to pop off sometimes. If the iron and silicon trend down next time I think I can write this UOA off to sludge clean-up.
I didn't bother with TBN or oxidation/nitration because they've never been an issue with this oil and service type, even with 4 times the kilometers on the oil.
170,000km on engine
99% hiway driving.
Esso XD3 0w30
Tin 0 0
Lead 2 0
Copper 5 0
Aluminum 3 1
Silicon 15 3
Iron 38 5
Chromium 0.7 0.4
Silver 0 0
Zinc 1200 1350
Magnesium 6 10
Nickel 0 0
Barium 0 0
Sodium 9 1
Calcium 2000+ 3800
Vanadium 0 0
Molybdenum 2 0
Boron 2 3
Manganese 12 1
PHYSICAL PROPERTIES
Water 0 0
Fuel Dilution No
