Maybe I should post this in the mechanical forum but I'm wondering if it's a lubrication problem. Maybe somebody can educate me on this engine; my son's fiancée has a Mitsubishi 3L V6 in a 2002 Eclipse GT. The car has 140k but has only been in the family for about the last 10k miles. The motor doesn't seem to have any sludge when you look through the filler cap and it doesn't darken the oil much over time. Last oil change was Pennzoil Platinum 5w30.
The issue is a heavy knocking noise when first started that takes quite a while to go away - she says it sometimes takes several minutes. I heard it once when we first started up after a starter change. The car was still jacked up so I thought it might just be the tilt of the engine hampering the oil pick-up. Once we de-jacked and re-started, it sounded normal. It just sounds like the oil hasn't pumped up so that sort of knocking. The oil level is fine and the filter is a Microgard. We took the filter off and cut it open but no sign of any sludge. When warm the engine is always nice and quiet.
Any characteristics of this engine that would cause this behavior? Seems to be an issue when cold since we didn't hear it last summer. Thoughts?
